First let me say I know this topic has been beaten to death, and I appologize for yet another post about it. This is a bit more technical, so I hope it can help others (as well as myself).
I have a CUSL2 with bios 1009. I purchased the upgradeware adapter and a Tualatin Celeron 1.1A.
http://www.upgradeware.com/english/product/370gu/370gu.htm
(I know I probably should have just done the socket mod, but lets not flame me too much for that mistake
As you all know, the CUSL2 bios will not allow core voltage adjustments if the CPU default voltage is below 1.65v.
Now, to the question. Is this wire mod used by the motherboard to set the CPU default, or by the CPU? It seems to me that it's used to set the default core voltage on the MB....that seems logical. But, I tried to do the wire mod, shorting Vid1 to Vid2, but the MB still doesn't detect the new default of 1.60v.
My next step is to try to set the default to 1.65 because I saw something else here about that being the minimum I can set with this MB, but back to the technical question. Should this mod work with this adapter, and it is to be done on the MB side of the adapter, or the CPU side?
Using a ohm meter I can see that the CPU, when inserted into the adapter, is set to default of 1.5v, which is what is detected in the MB too (Vid2 tied to Vss, all other Vid pins floating), but shorting Vid1 to Vid 2 doesn't change the default to 1.6v as indicated in the Intel datasheet.
And, another question, does the MAD bios tweak fix this core voltage setting so I can adjust the core voltage for Tualatin CPU's?
Any information about this, and more technical the better. I have a strong HW background, and some experience OC'ing, so I'm not as dumb as I look
Thanks.
Thanks.
