Some nice tips (continued)
If i do get 900 should i get better cooling, maybe a peltier?? Cant check temps MBM does not work on myt board, also it is not shown in the BIOS
Let's say you get your CPU to 700 without any L2 or voltage mod. No problems, but then it gets harder. 750 might need L2 adjustment (this is the point where stock L2 speed lowers, most of the chips rated above 3.3ns will fail at 1.6V). Maybe the core needs some extra voltage, say 1.65V. (hehe, this was my story, I've got an 650core with 3.3ns L2).
800, 850 needs 2/5 Cache, if you are lucky it still runs 1/2. Increased voltage for core. 1.7 should be fine if you ask me. You say you have no temp. measurement. Feel the base of the GORB wether it's warm. Warm=OK, getting hot for your hand means about 50°C. I use a car thermometer, attached the probe to the backside of the CPU, right under the core (my CPU is naked, no housing anymore). I used the foam included in my Mobo box to push the probe to the CPU and insulate it. GREAT tip when you are going to make some gaskets for peltiers, the stuff doesn't conduct and most of all IT'S FREE!
If you feel confortable, increase voltage to 1.8V. With proper cooling, this is ok. Just to refresh your mind: CPU's die because of HEAT, not of VOLTAGE (well, not entirely, but you get the drill..). I use 1.9V to run my CPU 850, and tried 875 with 2.0V. It booted once (!!
), but did not post and my mobo gave a overheated signal (it has no thermistor, but when your CPU get's unstable while running, mobo thinks it's overheated).
Peltiers are nice, watercooling is really recommended for them, the 0.25um cores of athlon produce MUCH heat, so you will need more than 80W.
900 is possible, but will require GOOD temps and extreme voltage, and of course much luck! If your core is willing, maybe you do the 900 with the GORB, maybe not...
When you get your GFD, maybe it's nice to see first what you can do with your standard aircooling. If you aren't pleased enough and want to go further, go and think about watercooling with or without a peltier. I was thinking about pelts for a while, but my major problem is to get a proper powersupply for the pelt and still get my setup stable!
Hey, maybe nice to mention. I've got a friend of mine willing to take his digital camera over here soon, so I can get pictures of my rig on the forum
Good luck OC'ing. Just remember not to do STUPID things, use your brain, and nothing will go wrong. And remember to let me know how things go!
Hope this explains, Greetings,
Rob
