- Sep 23, 2003
- Herzlya, Israel
Hey!
i read and reread the instructions dozens of times but im not sure about a couple things...
im gonna use the stuff on my p4c and a sp-94
Now im not quite sure what to use for everything, so please tell me if im right.
To clean of the stuff left by the stock intel cooler on the heatspreader, what do i refer to? Is it the same as removing the AS on the guide? (last part)
If not, what should i use?
Now to remove the AS from the heatspreader, what do i look at?
The part on CPU core of the part on Heatsink?
If it's CPU core, i plan to use either acetone and then isopropyl alcohol or directly high purity isopropyl alcohol.
If it's according to the heatsink party, then i will use mineral spirits. Whatever they are...
Please indicate which one it is
Next to remove the glue on the sp-94 after removing the plastic thing on the bottom i plan to use nail polish remover or acetone.
I should jsut leave the product on to evaporate, i should not wipe it off or rince it off after right?
So basically i just need to know what to do to:
remove the stuff left by the intel cooler
and clean off the stuff from the intel heatspreader (just tell me if it's considered Cpu core or heatsink... cuz it seems i have to use different products for each of those...)
Thx a lot!
Ritalin
PS: I also have a couple questions about installing the AS, please check this thread: http://www.ocforums.com/showthread.php?s=&threadid=257868
thx!
Thx a lot!
Ritalin
thx!
