- Dec 6, 2003
- Kent, UK
Hi,
I'm remounting the stock heatsink back onto my P4 (after using the original thermal pad). I've got some Arctic Silver 5 and have just read their instructions. they say...
"ONLY Arctic Silver thermal compound should be between the processor core and the heatsink. Remove any thermal pads or other interface material from the heatsink before applying the Arctic Silver. Thermal pads can be scraped off with a plastic tool that will not scratch the bottom then the remnants can be removed with a xylene based cleaner, (Goof Off and some carburetor cleaners) acetone, mineral spirits, Akasa TIM-Clean, or high-purity isopropyl alcohol."
...which is fair enough. but they go on to say...
"If your heatsink has a thermal 'pad' mounted on it, this pad must be removed before using Arctic Silver thermal compound. Thermal pads are made with paraffin wax that melts once it gets hot. When it melts, it will fill in the microscopic valleys in the heatsink with wax. To minimize the permanent contamination of the mounting surface with wax, the thermal pad should be removed before it is used and melted. Never use heat or hot water to remove the pad, the heat will melt the wax into the heatsink."
So it's quite likely that my HS might be permanently contaminated with the wax. Is my only choice to lap the HS or will Goof Off suffice?
Also what should I use to remove any remaining wax residue from the CPU?
