- Jan 9, 2002
- New Jerzy
the idea: 18 x 18 x 9.... all plexi glass.... how to make it stay togeather....? any idea's would be helpful
m_mike_k said:epoxy and or those L shaped metal things screwed to the case sides. Thats just from reading articles, I've never built a plexi case. Are you going to put a window in?![]()
h20link said:
Avatar28 said:
What's sad is I almost clicked on the reply button before I realized that was a joke. Maybe he should put in an anti-window. A piece of metal inside part of the plexiglass.![]()
CrystalMethod said:
Dead link.
A drill, a tap and die set, some set screws and a steady hand would be my choice. Unless you're going for the seamless, no visible fastener aproach.
