Although Mcmaster.com is mentioned in the stickies, where to find this tubing on their site is not. I thought it might help those of you like me out there looking for Clearflex 60 at a reasonable price. Do a search for 5231K237 (it is on catalog p. 85). The website does not tell you that this is Clearflex 60, but it is (just got it in the mail today). The 3/8" ID, 1/2" OD, 1/16" wall (5231k186) is .23 cents per foot, the 3/8" ID, 5/8" OD, 1/8" wall (5231k218) is .51 cents per foot, and 1/2" ID, 3/4" OD, 1/8" wall (5231K237) is .68 cents per foot (as of Feb 05), just to name a few common ones. Frozen CPU for instance charges $2.00 per foot just for the 3/8" ID, 1/2" OD, 1/16" wall Clearflex 60.
They also have clamps of all types and all kinds of plumbing items and adapters, although you do have to buy them in small quantities.
Another thing they carry is Melamine Foam Sound Absorbing Ceiling Tile 2'x2' Number 9216T1, catalog page 3271 . It is foam with a thin hard smooth coating outside that worked great for lining the inside of my computer compartment Because you can cut it to size and it is stiff. It really helped get the whine of my MCP650 down.
I hope this helps.
I hope this helps.
