Clock Generator is running too hot any suggestions on cooling
warduck
Im using an abit be6-2 mobo, the clock generator needs to be cooled as its running 33c at idle. Any suggestions.
warduck
I've noticed the clock gen on my A7V runs really hot as well. I've got no temp data right now(should by week's end), but I am definately trying to come up with something effective. I don't wanna have to cut up another heatsink(its such a pain), but I want something small enough to fit. Maybe a RAM cooler or two?
I'll be sure to post whatever I do finally work out.
joe has a great article on putting a tennmax bga cooler on the a7v's clock gen. look under the cooling section of the articles on the main page. i've done, and it works great.. nice copper cold-plate and a small p1 cooler do the trick just fine.
Radio Shack has a solid aluminum dram heatsink for like two bucks. what you can do is take a small amount of thermal paste in the center of the clock generator chip and apply a VERY THIN amount of super glue on the four corners of the chip to set it.
I was able to lower my core voltage to 1.65v on a cB0 700e and still run at 1022 mHz with the mod..ROCK SOLID...
