The system i have right now currently uses a resevoir which works out well because it's in a large case. I plan on building a second box with some extra parts i have around but the case I have is fairly small. At first I thought about just buying a larger case, but then i considered just running a closed loop system, eliminating the space need for a resevoir. A small in-line pump could easily push the water around.
Are there any advantages or disadvantages to running a setup like this? Also, if someone could shead a little light on adding a bleeding/expansion hose it would be appreciated.
Thanx in advance!
Thanx in advance!
