CNPS9700 LED or Scythe Ninja?
Faux Carnival
Hi everybody, I'm looking for a good and cheap CPU cooling for my Core 2 Duo.
Since Scythe Ninja got excellent scores on almost every review, I was planning to buy that. But CNPS9700 LED is out too and it's a great, silent CPU cooler with a nice LED fan and Zalman quality.
Also there is one more good choice: Thermaltake Big Typhoon, which is also a great cooler.
I'm confused. TT BT and Ninja are lower priced coolers. But if CNPS9700's performance is better, I might also go for Zalman too.
Go with the TTBT or Ninja you can upgrade the fans for even better cooling and they are cheaper.
{FKR}Loki said:
Go with the TTBT os Ninja you can upgrade the fans for even better cooling and they are cheaper.
either will do just fine, also look into the thermalright Ultra-120
