- Apr 10, 2010
How can I accomplish this I'm a little confused I never heard of a coaxial cable. Tv I have only has coaxial audio out. My sound bar has the typical rcas and aux. Can't find a coaxial to aux or rcas. What can a man do?
You can get a coax to optical converter.
It's a digital device and using the analog inputs would likely lead to less than optimal results.
Look at the picture of the device. It has an optical input, which is the best one to use if possible.
