- Jan 4, 2001
- Northern VA
I'm sure we all remember Hoots wonderful article on cohesive air.
While at work yesterday, we have some leaf blowers (electric) that we use to create air cirulation in ducting to take air samples. Well, being the IT guy, when they broke one of them, I was asked to fix it...hey it was electonic
I've never looked close at an electric blower (although I've fixed a number of gas ones). Its a very simple design...the motor, with a turbine attached directly to it. above the turbine is a circular grate for the air intake. The turbine spins, sucking in air and blowing it straight out the tube...much like the cohesive air blower.
As you know, they put out alot of airflow too...gotta blow leaf piles with the thing, so it better.
I was thinking, these could be an alternative to the blower Hoot used...they're very easy to find. Home Depot had a Toro 140mph electric blower for $32 too. The casing is mostly plastic, so its easy to cut, paint, or mod to fit your case, maybe build a bracket for it.
I may give it a shot someday, although i'm already collecting things for watercooling, so I'll probably skip over this idea.
Hoot if you read this, feel free to input!
Mike
Mike
