I do check the front page this time
QUOTE
UPDATE 1/8/01: Some Application Notes
Gabriel Rouchon of Swiftech was generous enough to share his thoughts about some general cold plate guidelines based on the years of their testing:
"Air cooled TEC's require thicker cold plates to move the CPU as far away as possible from the hot side (the heat sink) and reduce parasitic heat radiated back by the heat sink towards the cold side. In that case, cold plates are actually referred to as "spacer blocks". We use copper blocks as thick as 1/2" for this.
END QUOTE
I'm now using a 3/8"x4cmx4cm (HWL) copper cold plate. Want to know what will happen if I use a 1"x 2" x 2" or 2"x2"x2" copper block instead. As this is pretty inexpensive buying from metal shop so I don't mind buying a larger one. I suppose it works like a thermal buffer or reservoir so temp fluctuation can be minimised. My CPU idles at 16C and can go beyond 40C under 100% load gradually. I suppose using a larger plate (block) can extend the time for it to heat up. Probably need foam and masking tape to wrap it up? May also need a shim to avoid the 1 lb block crushing the die? And something to support the mobo on the bottom
Anything else I need to know? oh yes I'm uising desktop case, no worry, and don't move it around
thanks
QUOTE
END QUOTE
thanks
