Coldest Single Stage?
tjh566
Va
I built a single stage not too long ago, it hit -30c, i charged it with 404, I was wondering how cold a single stage can go with a decent sized heat load and how to do this.
Sam__
UK
as far as i know it depends a lot on the components you use and the gasses.
coldest i have seen are custom rotary builds in the -55 area.
T
tjh566
Va
-55 would be sweet, i got a rotary sitting in the garage I can use.. what gas should i use to reach those temps?
NoL
NJ, USA
Not that simple.
It's a balance of load versus temperature, and even then, going deep into vacuum will in quick time destroy your compressor internally.
T
tjh566
Va
Althought My questions/statements seem noobish there is no need to dismiss. I do have Hvac field experience but this is different than say a rooftop unit, My experience Is lacking with this extreme low temperature area.
Say I wanted -55c with a 200watt-ish heat load, what refriderant would be best suited for this application?
NoL
NJ, USA
In any situation like that, something that boils COLDER then -55C @ 1atm.
Say... R23. Or R170.
You truly do not ever want to run in sub 1atm conditions "0 psi" on the low side.
T
tjh566
Va
So the most practical way of getting "close" to this goal would be 410a?
NoL
NJ, USA
R410a boils at -51.6C at 1atm.
So it would still need to be run into a vacuum.
R410a is also VERY hard to condense, a warm room will run you up past 300 psi.
That makes a very unhealthy system.
