CompuNurse Temp Monitoring.. how to install?
Emericana
Boulder CO
My 8k3a does not give accurate temps on the bios and i would really like to know what my temps are. i find it very hard to believe that on my old 8kha+, before it broke (long story), i got around 40C load w/ my pal 8045 and on my 8k3a+ i get around 50C load. There have also been numerous other reports of the same temp incidents w/ that board...
since i bought this board because of its great overclocking feature, i would obviously like to know what my temp is before i pump it up to 1.95 Vcore.
The temp monitoring prope called compunurse (can be found on 2cooltek.com in the gear section) gives you a accurate temp but i really have no clue how to install it. Will i need to take off my heatsink (pain in the *** cause i need to take off my whole entire mobo) or is there a easier way.... do i hook something upto the processor or something? anybody know? anybody have alink wih a tutorial on how to do this?
thanks
