Hey guys, it's been a while since I have been on. Been doing a lot of reading on the forums today and learned some new stuff, and freshened up on some stuff I already knew. If one of you super computer guys out there could just give my PC a quick check up... I'll post my dxdiag and tell me if there is anything I should update (software wise) or anything that looks fishy.
Thanks
System Information
Time of this report: 11/28/2006, 16:51:24
Machine name: CD-DFF4V7GU5YYK
Operating System: Windows XP Professional (5.1, Build 2600) (2600.xpclient.010817-1148)
Language: English (Regional Setting: English)
System Manufacturer: VIA Technologies, Inc.
System Model: KT880-8237
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) XP 2800+, ~2.2GHz
Memory: 1024MB RAM
Page File: 644MB used, 1818MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6800
Manufacturer: NVIDIA
Chip type: GeForce 6800
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0041&SUBSYS_81EA1043&REV_A1
Display Memory: 512.0 MB
Current Mode: 1280 x 1024 (32 bit) (72Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9147 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/11/2006 20:42:52, 4496128 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 8/11/2006 20:42:42, 3958496 bytes
Device Identifier: {D7B71E3E-4301-11CF-4850-E0A100C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0041
SubSys ID: 0x81EA1043
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Live! Wave Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0002&SUBSYS_80271102&REV_07
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: emu10k1m.sys
Driver Version: 5.12.0001.3300 (English)
WHQL Logo'd: Yes
Date and Size: 8/17/2001 04:19:26, 283904 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 5000, 100000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SB Live! MIDI UART, Hardware (Kernel Mode), Input, No DLS, External
SB Live! MIDI UART, Hardware (Kernel Mode), Output, No DLS, External
SB Live! Wave Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
B: SB Live! MIDI Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
A: SB Live! MIDI Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI UART [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI UART [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Logitech Gaming Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC221
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: G15 Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC222
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/23/2001 04:00:00, 50688 bytes
| Driver: usbd.sys, 8/23/2001 04:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/23/2001 04:00:00, 62464 bytes
+-+ Creative SBLive! Gameport
| | Matching Device ID: pci\ven_1102&dev_7002
| | Lower Filters: ctljystk
| | Service: gameenum
| | Driver: ctljystk.sys, 8/17/2001 04:19:20, 3712 bytes
| | Driver: gameenum.sys, 8/17/2001 06:02:32, 9728 bytes
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/17/2001 12:48:04, 13952 bytes
| Driver: kbdclass.sys, 8/23/2001 04:00:00, 23424 bytes
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/17/2001 21:38:00, 37896 bytes
+ HID-compliant MX518 Optical Mouse
| Vendor/Product ID: 0x046D, 0xC01E
| Matching Device ID: hid\vid_046d&pid_c01e
| Upper Filters: LMouKE
| Lower Filters: LHidKE
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 12:48:00, 12160 bytes
| Driver: mouclass.sys, 8/17/2001 12:47:58, 22016 bytes
| Driver: LHidKE.Sys, 12/10/2004 11:48:46, 24704 bytes
| Driver: LMouKE.Sys, 12/10/2004 11:48:40, 68992 bytes
| Driver: KHALMNPR.Exe, 12/10/2004 11:45:26, 49152 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 48.1 GB
Total Space: 78.2 GB
File System: NTFS
Model: Maxtor 6L080L0
Drive: D:
Model: HL-DT-ST DVDRAM GSA-4163B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.0000 (English), 8/23/2001 04:00:00, 47488 bytes
System Devices
Name: ADMtek AN983 based ethernet adapter
Device ID: PCI\VEN_1317&DEV_0985&SUBSYS_EC021113&REV_11\3&13C0B0C5&0&48
Driver: C:\WINDOWS\System32\DRIVERS\an983.sys, 2.12.0507.2001 (English), 8/17/2001 04:11:16, 34112 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1106&DEV_B198&SUBSYS_00000000&REV_00\3&13C0B0C5&0&08
Driver: C:\WINDOWS\System32\DRIVERS\pci.sys, 5.01.2600.0000 (English), 8/23/2001 04:00:00, 62464 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1106&DEV_7269&SUBSYS_00000000&REV_00\3&13C0B0C5&0&07
Driver: n/a
Device ID: PCI\VEN_1106&DEV_4269&SUBSYS_00000000&REV_00\3&13C0B0C5&0&04
Driver: n/a
Device ID: PCI\VEN_1106&DEV_3269&SUBSYS_00000000&REV_00\3&13C0B0C5&0&03
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1106&DEV_3227&SUBSYS_00000000&REV_00\3&13C0B0C5&0&88
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 04:00:00, 35840 bytes
Name: RAID Controller
Device ID: PCI\VEN_1106&DEV_3149&SUBSYS_300C1695&REV_80\3&13C0B0C5&0&78
Driver: n/a
Name: Universal Serial Bus (USB) Controller
Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_31041106&REV_86\3&13C0B0C5&0&84
Driver: n/a
Name: VIA Compatable Fast Ethernet Adapter
Device ID: PCI\VEN_1106&DEV_3065&SUBSYS_30051695&REV_78\3&13C0B0C5&0&90
Driver: C:\WINDOWS\System32\DRIVERS\fetnd5.sys, 2.66.0000.0290 (English), 8/17/2001 04:13:08, 27165 bytes
Name: Multimedia Audio Controller
Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_300C1695&REV_60\3&13C0B0C5&0&8D
Driver: n/a
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381106&REV_81\3&13C0B0C5&0&83
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.0000 (English), 8/23/2001 04:00:00, 18944 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.0000 (English), 8/23/2001 04:00:00, 123264 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 14:36:34, 67072 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.0000 (English), 8/23/2001 04:00:00, 50688 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381106&REV_81\3&13C0B0C5&0&82
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381106&REV_81\3&13C0B0C5&0&81
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381106&REV_81\3&13C0B0C5&0&80
Device ID: PCI\VEN_1106&DEV_2269&SUBSYS_00000000&REV_00\3&13C0B0C5&0&02
Driver: n/a
Device ID: PCI\VEN_1106&DEV_1269&SUBSYS_00000000&REV_00\3&13C0B0C5&0&01
Driver: n/a
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711106&REV_06\3&13C0B0C5&0&79
Driver: C:\WINDOWS\System32\DRIVERS\viaide.sys, 1.00.0001.0000 (English), 8/23/2001 04:00:00, 4352 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.0000 (English), 8/23/2001 04:00:00, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 5.01.2600.0000 (English), 8/23/2001 04:00:00, 86656 bytes
Device ID: PCI\VEN_1106&DEV_0269&SUBSYS_00000000&REV_00\3&13C0B0C5&0&00
Driver: n/a
Name: Creative SBLive! Gameport
Device ID: PCI\VEN_1102&DEV_7002&SUBSYS_00201102&REV_07\3&13C0B0C5&0&51
Driver: C:\WINDOWS\system32\drivers\ctljystk.sys, 5.01.2501.0000 (English), 8/17/2001 04:19:20, 3712 bytes
Driver: C:\WINDOWS\System32\DRIVERS\gameenum.sys, 5.01.2600.0000 (English), 8/17/2001 06:02:32, 9728 bytes
Name: Creative SB Live! Value (WDM)
Device ID: PCI\VEN_1102&DEV_0002&SUBSYS_80271102&REV_07\3&13C0B0C5&0&50
Driver: n/a
Name: NVIDIA GeForce 6800
Device ID: PCI\VEN_10DE&DEV_0041&SUBSYS_81EA1043&REV_A1\4&8CA73A7&0&0008
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0010.9147 (English), 8/11/2006 20:42:42, 3958496 bytes
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0010.9147 (English), 8/11/2006 20:42:52, 4496128 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0010.9147 (English), 8/11/2006 20:42:50, 155715 bytes
Driver: C:\WINDOWS\System32\nvhwvid.dll, 6.14.0010.9147 (), 8/11/2006 20:45:20, 581632 bytes
Driver: C:\WINDOWS\System32\nvapi.dll, 6.14.0010.9147 (), 8/11/2006 20:43:10, 196608 bytes
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0010.9147 (English), 8/11/2006 20:42:58, 5636096 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0010.9147 (English), 8/11/2006 20:43:02, 7630848 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0010.9147 (English), 8/11/2006 20:43:04, 86016 bytes
Driver: C:\WINDOWS\System32\nvwddi.dll, 6.14.0010.9147 (English), 8/11/2006 20:43:08, 81920 bytes
Driver: C:\WINDOWS\System32\nvnt4cpl.dll, 6.14.0010.11048 (English), 8/11/2006 20:43:00, 286720 bytes
Driver: C:\WINDOWS\System32\nvmccs.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:22, 229376 bytes
Driver: C:\WINDOWS\System32\nvdisps.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:28, 5611520 bytes
Driver: C:\WINDOWS\System32\nvdispsr.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:30, 5251072 bytes
Driver: C:\WINDOWS\System32\nvgames.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:32, 3039232 bytes
Driver: C:\WINDOWS\System32\nvgamesr.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:34, 2928640 bytes
Driver: C:\WINDOWS\System32\nvmccss.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:38, 188416 bytes
Driver: C:\WINDOWS\System32\nvmccssr.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:40, 458752 bytes
Driver: C:\WINDOWS\System32\nvmobls.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:42, 888832 bytes
Driver: C:\WINDOWS\System32\nvmoblsr.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:42, 2859008 bytes
Driver: C:\WINDOWS\System32\nvvitvs.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:44, 2904064 bytes
Driver: C:\WINDOWS\System32\nvvitvsr.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:46, 2953216 bytes
Driver: C:\WINDOWS\System32\nvwss.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:36, 1236992 bytes
Driver: C:\WINDOWS\System32\nvwssr.dll, 6.14.0010.9147 (English), 8/11/2006 20:45:38, 1732608 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 8/11/2006 20:43:06, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 8/11/2006 20:43:00, 55444 bytes
Driver: C:\WINDOWS\System32\nvcod.dll, 1.00.0000.0035 (English), 8/11/2006 20:42:44, 35840 bytes
Driver: C:\WINDOWS\System32\nvcodins.dll, 1.00.0000.0035 (English), 8/11/2006 20:42:44, 35840 bytes
DirectX Components
ddraw.dll: 5.03.0001.0904 English Final Retail 7/9/2004 03:27:28 292864 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 10496 bytes
d3d8.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1201152 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1703936 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 08:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 04:00:00 33040 bytes
dplayx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 230400 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 77824 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 04:00:00 42768 bytes
dpwsockx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 79360 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 723968 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 381952 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 08:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 04:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00 648704 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 8/29/2002 02:40:00 667648 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 467968 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 208896 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 223232 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744 bytes
gameenum.sys: 5.01.2600.0000 English Final Retail 8/17/2001 06:02:32 9728 bytes
dsound.dll: 5.03.0001.0904 English Final Retail 7/9/2004 03:27:28 381952 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 491520 bytes
dmusic.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 122880 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 181248 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1769472 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 04:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 8/23/2001 04:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 21504 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 132608 bytes
dxmasf.dll: 6.04.0009.1120 English Final Retail 8/23/2001 04:00:00 498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/11/2002 23:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 12:44:28 221184 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 316928 bytes
qdvd.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 470528 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 1798144 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 08:00:02 1962496 bytes
strmdll.dll: 4.01.0000.3925 English Final Retail 8/23/2001 04:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/23/2001 04:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/23/2001 04:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/23/2001 04:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/23/2001 04:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/23/2001 04:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/23/2001 04:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/23/2001 04:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/23/2001 04:00:00 154624 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 324096 bytes
msdvdopt.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 74240 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/11/2002 23:14:32 4096 bytes
stream.sys: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 48512 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
kstvtune.ax: 5.03.0001.0904 English Final Retail 7/19/2004 16:19:30 285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
WMVideo 9 Decoder DMO,0x00600800,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0904
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4477
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4477
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
File Source (Netshow URL),0x00400000,0,1,dxmasf.dll,6.04.0009.1120
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0904
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4477
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Ulead MP3 Encoder,0x00100000,2,1,uleamp3.ax,
Windows Media Multiplexer,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASX file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASX v.2 file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1120
NSC file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,dxmasf.dll,6.04.0009.1120
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0904
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
SmartSound Soundtrack,0x00400000,0,1,DirectQX.dll,3.00.0002.0007
SmartSound SDS Reader,0x00400000,0,1,SDSReader.dll,3.00.0002.0007
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.02.0005.0034
Ulead DVD Video decoder 2,0x00400000,2,2,ulDVDVideo.ax,
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4477
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0904
ULead Infinite Pin Tee,0x00200000,1,1,uinftee.ax,
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0904
Ulead MPEG-4 Encoder,0x00200000,2,0,ulmp4enc.ax,
Ulead MPEG-4 Splitter,0x00600000,1,3,ulspmp4.ax,1.00.0004.0000
Ulead MPEG-4 Audio Decoder,0x00400000,1,1,uladmp4.ax,
Ulead MPEG-4 Video Decoder,0x00400000,1,1,ulvdmp4.ax,
Ulead AMR Audio Decoder,0x00800000,1,1,uladamr.ax,
Ulead MPEG-4 ASP Video Decoder,0x00400000,1,1,ULASPV~1.AX,
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
.RAM file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1120
Ulead DVD Audio decoder 2,0x00200001,1,1,ULDVDA~1.AX,
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0904
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,dxmasf.dll,6.04.0009.1120
ASF DIB Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF ACM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF ICM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF URL Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF JPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF DJPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF embedded stuff Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMP CD Filter,0x00600000,0,1,wmpcd.dll,8.00.0000.4477
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0904
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1477
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Ulead MPEG Splitter,0x00400002,1,2,ulspmpeg.ax,1.00.0000.0104
Ulead MPEG Audio Decoder,0x00400000,1,1,ULDVDA~1.AX,
Ulead MPEG Video Decoder,0x00400000,1,1,uldsmpeg.ax,
Ulead MPEG Encoder,0x00200000,2,1,ulesmpeg.ax,
Ulead MPEG Audio Encoder,0x00200000,1,1,uleampeg.ax,
Ulead MPEG Muxer,0x00200000,5,1,ulmxmpeg.ax,
Ulead LPCM Audio Encoder,0x00200000,1,1,ulpcmpeg.ax,
ULead File Source (Async.),0x00400000,0,1,ulasync.ax,
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,dxmasf.dll,6.04.0009.1120
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
Ulead DVB Parser,0x00200000,1,0,ulDVBParser.ax,
Ulead Audio Dual Channel Filter,0x00200000,1,1,UAudioDCFilter.ax,
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.0000.0900
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0904
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX® 6.4.0 Codec (1 Logical CPU),0x00200000,1,1,qcap.dll,6.05.0001.0900
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX® 6.4.0 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
SB Live! Wave Device,0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
A: SB Live! MIDI Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
B: SB Live! MIDI Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! MIDI UART,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
SB Live! MIDI UART,0x00200000,3,2,,5.03.0000.0900
SB Live! Wave Device,0x00200000,3,2,,5.03.0000.0900
WDM Streaming Rendering Devices:
A: SB Live! MIDI Synth,0x00200000,1,1,,5.03.0000.0900
B: SB Live! MIDI Synth,0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00200000,2,2,,5.03.0000.0900
Audio Renderers:
SB Live! Wave Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: SB Live! Wave Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming System Devices:
A: SB Live! MIDI Synth,0x00200000,10,2,,5.03.0000.0900
SB Live! Wave Device,0x00200000,12,2,,5.03.0000.0900
Thanks
System Information
Memory: 1024MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0041
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
+ PCI bus
| Service: pci
| | Service: gameenum
PS/2 Devices
| Service: kbdhid
| Service: kbdhid
| Service: TermDD
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 48.1 GB
File System: NTFS
Drive: D:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
,0x00000000,0,0,,
,0x00000000,0,0,,
Audio Renderers:
