Computer Modding Part List
Automata
Automata
Destroyer of Empires and Use
It probably is, but I'm looking for places that sell it in bulk and for cheaper. Finding the parts isn't a problem. Finding them for a reasonable price is.
nomadcrossfire
Btw the pcie connectors i linked come with the pins, so they r pretty cheap, even if not in bulk, concidering the price of the pins themselves
Edit:
O, they do sell them in bulk also.
Automata
Automata
Edit:
The price is ok. ATX pins are $0.04 each on Mouser, which leaves $0.68 for the plastic connector.
nomadcrossfire
The links you have posted on the first page for the molex pins are 17c each for male and 18c for female. Maybe im reading the pricing wrong some how?
Edit:
My bad im a nub, i thought they used molex as you can see, but now i see where i was wrong, my bad.
Edit 2:
Any chance you could help me find male atx pins? Im going to need to make an adapter to do dual psu, and i was just gonna clone the lian-li one, which would require a male pin...
Automata
Automata
I probably won't be able to look today, as I have quite a few things I need to do, but I should be able to find them eventually, yes. You may have to periodically remind me, though.
nomadcrossfire
I no longer need the male atx pins, but I was wondering how many sata pins you need per sata connector, bcuz it looks like you need multiple and my psu cables have 5 or 6 cables connected to the sata connectors. Don't remember exactly how many and I'm at work atm. And also what is the recommended gauge for sata power? 20-22 awg?
Automata
Automata
SATA has "15 pins", but each pin has three pins. So, you need five pins for a full connector. If you don't do the 3.3v pin, you need four. 20-22 AWG is fine depending on how many amps you are running through them.
nomadcrossfire
Should I just stick to the 18awg I'm using for the rest to b safe? Idk how many amps my psu will throw thru the cables
Automata
Automata
Your power supply doesn't push power through the cables. The devices draw them. If you are just running a few hard drives, 20-22 AWG is more than enough.
Automata
Automata
I just added three more parts to the list.
USB - These pins don't work with the connectors I have on hand, but they do work with the connectors I purchased. I've verified that they work on a board.
"Stock" USB/1394 pin
I also got a 6-pin PCIe power connector.
TiZakit
Doylestown, Ohio
SATA Molex power punchdown connector:
Molex #: 67926-0015
http://www.molex.com/molex/products/datasheet.jsp?part=active/0679260015_IDT_AND_SOLDER_CON.xml
Mouser #: 538-67926-0015
http://www.mouser.com/ProductDetail...=/ha2pyFadugdhdMNojSIiiECSaWZnJhekwAIkSMi3TA=
Use these with the feed-to-cover or feed through covers:
Feed-to-cover: Molex #: 67926-0040 Mouser # 538-67926-0040
http://www.mouser.com/ProductDetail...=/ha2pyFadugdhdMNojSIipaRGjFpPb1crzwHMpopltE=
Feed through cover: Molex #: 67926-0041 Mouse #: 538-67926-0041
http://www.mouser.com/ProductDetail...=/ha2pyFadugdhdMNojSIioxqVZSetzQE5FhhzoZki8k=
Datasheet says 5 circuits and uses 18AWG wire.
SeeThruHead
Toronto, Canada
Can anyone link me the part number or url for a 4pin right angle molex KK connector with the friction lock like a 3 pin. Basically the part used on motherboards for connecting pwm fans, but right angle versions.
SeeThruHead
Toronto, Canada
EDIT:
I can find these no problem:
LL
But the locking tab is 4 pins rather than 3 which is what pc fans use. Like this:
I need that but with right angle pins like this:
