- Jan 4, 2001
- Northern VA
Well, just the other day, I redid this ladies computer at work. Reformatted, reinstalled Windows, etc etc. Got it back to her, and it was running great, a K62 500mhz on a crummy TigerDirect board, probably a PC Chips.
So, all things considering, it was running great. But today, she called me b/c she was having issues with it.
So I went to see what was wrong, and I found as I reached down to turn it on, that there was a space heater running at full blast pointed right at the front of the case.
The ambient air around the front of the case was VERY hot. My hand didn't want to stay there too long...it was 1 foot from the heater.
The cpu has a decent heatsink and fan (as of the other day...the one it had on it was anemic at best), and a front case fan, which undoubtedly was pulling in this nice cool air
Took it back to my desk, opened it up, and it was quite hot inside.
Not sure how much damage was done, but the thing wouldn't boot for ANYTHING. I swapped every part I could, different cpu, different ram, different PSU. I had all peripherals disconnected, and even pulled the board from the case to be srue there were no bad grounds.
Finally dug up and old PCI video card and it booted right up. So looks like the onboard video is now dead, probably due to the heat.
Ofcourse, SiS530 onboard video is nothing to cheer about, but now she's running an old Number Nine s3 trio64 card that I pulled from an old Dell Pentium 90. It'll do 800x600 at 16bit, but go to 1024x786 and you gotta settle for 256 colors
So since others in the office have space heaters and insist on putting their systems near them to "save desk clutter", I think it's due to time for a memo. A memo that explains what happens to cpu cooling when you raise the ambient temperate. For instance, when your ambient temperature right outside the case is 40 degrees higher than the normal air, you can expect your computer to not be able to handle that.
Even with great cooling, it's tough to keep a computer cool with a space heater on high 1 foot from the front intake
Mike
Mike
