I'm planning to install a watercooling system since I'm using Athlon XP2000 (overclocked) and the heatsink is very much noisy even when I use bigger fan. How much degrees maximum I can expect if I use watercooling on my system and overclock?
I'm wondering if there's any condensations from water cooling system that might occur?
When using water cooling, do I have to have a bucket full of water to pump the water to/from the pump?
I also think to attach one for the chipset, do you think it'll make much difference, attaching waterblock on chipset than attaching fan like Orb TT? Also will it lower the VCore temperature?
Also, do I have to clean the whole water cooling system once awhile?
