I've been watercooling for some time now and have decided to move to peltier cooling. I'm trying to figure out the best way to hook things up and I'm sure I can get some opinions here.
I have the following:
CPU:
Mobile 2400+ (1.35v)
DangerDen Maze4-1 + 226w TEC
GPU:
9800XT
Swiftech MCW50-T w/ 80w TEC. Will swap out for 172w.
Chipset:
Nforce2 (NF7-S v2)
DangerDen Maze4 Chipset Block. Will use the 80w from GPU block.
Copper Heater Core - about 10"x6"x2" (from an old chev if I remember correctly)
Black Ice Micro 80mm Rad. Rated for 275w.
700+ GPH pump.
double 3 1/2" bay reservoir.
Everything is 1/2" ID
550w TrueControl PSU for main power.
Have several 350-400w PSUs lying around so I'll probably use a couple of them for the pelts.
Have not done any volt mods as of yet, but I'm sure they'll happen.
So, after doing a fair amount of reading, it seems that the general consensus is that rads in parallel are better than in series. The point that really convinced me is the fact that you want the water going into each rad as hot as possible for better cooling efficiency. Also, the pelts will be in paralell (mostly), as I dont dare connect them in series. I figure that is just asking for trouble.
So I'm planning the following and would invite people to pick it apart:
Pump-->CPU-->Big Rad-->Res
--->GPU-->NB-->Little Rad-->Res
Wasn't sure which rad should go where. This was my first thought, but knowing how much heat those 9800XTs put out is making me reconsider. Also, the combined output of the 2 TECs on the GPU/NB path is greater than the 1 TEC on the CPU path. Or maybe I should move the rads after the res. so the water has a chance to mix and the heat is distributed more evenly?
Also, I thought about connecting the GPU and NB in parallel as well, but I'm not sure if the flow would be too low at this point. (Would the flow be 1/3 or 1/4 of that coming out of the pump at this point?) If I do leave them in series is it better to have the hotter one first or last?
Finally, do I need to use a cold plate on the NForce2? I realize it has a "heat spreader" already, but I dont know if this is sufficient or not. I would use one just to be safe, but I can't seem to find one.
Think that's about it. Sorry if I rambled on (gonna ramble on, sing my song... oh sorry...). Any help would be greatly appreciated.
Promise to let you know how it turns out...
Thanks in advance.
CPU:
GPU:
9800XT
Chipset:
Nforce2 (NF7-S v2)
700+ GPH pump.
Thanks in advance.
