- May 6, 2008
-Budget ~$200, less is better
-Monitor 2560x1440 dell ultramon
-60Hz
-My budget says I will have to run new games at 1080.
-2600k
-16GB Mem
Currently have 7950 3G windforce
I was looking at rx 480/580 on ebay just now. A quick search shows a lot of very cheap used $120 480's 8GB and $160 580's cards on ebay. Most likely from mining.
Any reason to not buy a 580 mining card? Assuming it was not abused in a hotbox. But I figure most people that want to make money are smart enough not to risk burning up there $300-400 card. Also buying a used reference style/cheap 480/580 would allow me to afford the SXPC 480/580 in our classifieds section. (nothing like throwing $60 at a water block that will gain you $10-20 worth of increased performance).
I am looking for best bang for buck new or used. A quick search on newegg shows 580's about $200 and dropping. Seems like a decent deal. 1070 is out of my price range.
Thoughts? Been so long since I have really looked into a build. Last build was q6600, lol. The 2600k I have now was a pity hand me down from a friends. The mobo on/off pins are broken and I have a ps2 keyboard hooked up and wake on through that. USB Wake On will not work.
Conclusion. For $200 a new 580 8GB is my best bet. Used 480/580 is a risk but worth it???
If I am missing something or incorrect please tell me.
Thanks.
-60Hz
-2600k
-16GB Mem
Thanks.
