I've been recommended to use Prime95 for testing the stability of my underclocked/undervolted CPU, but there are many different answers to how long I should let it run to be (more or less) sure the system is stabil. I've heard/read everything from 10-15 minutes to 24hours, so I'm a bit confused about it all.
In addition:
Which type of Prime95 test should I run, when it's only the CPU that has been modified?
Can I run other programs while Prime95 is running its tests?
My motherboard/bios does not support reading the CPU core temp from the built-in sensor of the CPU, but uses a sensor placed on the motherboar, underneath the CPU. How many degrees (approx) should I add to this readout to get the actual core temperature?
All help on this is very much appreciated!
In addition:
