confused tualatin wire trick
peter p
I hav a tualatin 1.2 with default voltage of 1.5. When I read the sticky post on how to do the wire trick, it says if you connect the vid 1 to vid 2 and it will increase the voltage from 1.45 to 1.65.
Do I do the same for the tualatin 1.2 with 1.5 default voltage and if so what voltage will I get at default. Will my bios voltage settings now include voltages up to 1.80 and above?
My mobo is a Abit VH6T and my voltage only goes up to 1.70 and I have my FSB overclocked to 128 stable. I know if I increase the voltage to at least 1.80 I can reach 133 FSB.
Can anyone help me on this, also is 1.80 volts too much for the tualatin?
You must have one of the newer 1.2 Tualatin chips, which has a default voltage of 1.500 instead of 1.475 volts. This means that you will need to connect different pins to up the voltage. However, let me first say you are risking your chip if you go over 1.700 volts. Some people have certainly done it, but you do increase the risk.
Following is the default voltage pin table. If you connect Vid1 to Vid2, you will change your voltage from 1.500 (01011) to 1.600 (01001). Note - if you connect a 1 pin to a 0 pin, the 1 pin will change to a 0. This would allow you to increase your voltage up to 1.800 via the BIOS (1.600 + 0.2).
0 = Processor pin connected to VSS and 1 = Open on processor
VID25mV VID3 VID2 VID1 VID0 VccCORE
0 0 1 0 0 1.05
1 0 1 0 0 1.075
0 0 0 1 1 1.10
1 0 0 1 1 1.125
0 0 0 1 0 1.15
1 0 0 1 0 1.175
0 0 0 0 1 1.20
1 0 0 0 1 1.225
0 0 0 0 0 1.25
1 0 0 0 0 1.275
0 1 1 1 1 1.30
1 1 1 1 1 1.325
0 1 1 1 0 1.35
1 1 1 1 0 1.375
0 1 1 0 1 1.40
1 1 1 0 1 1.425
0 1 1 0 0 1.45
1 1 1 0 0 1.475
0 1 0 1 1 1.50
1 1 0 1 1 1.525
0 1 0 1 0 1.55
1 1 0 1 0 1.575
0 1 0 0 1 1.60
1 1 0 0 1 1.625
0 1 0 0 0 1.65
1 1 0 0 0 1.675
0 0 1 1 1 1.70
1 0 1 1 1 1.725
0 0 1 1 0 1.75
1 0 1 1 0 1.775
0 0 1 0 1 1.80
1 0 1 0 1 1.825
Hi guys,
I know this is a really old post but i just need someone to let me know how to work out which corner is which on the tualatin chip. Basically the diagram in the sticky gives the locations of the pins in the top-right corner, but how do I know if i've got the chip the right way up? Which corner is the top right? And are the pins facing towards me or away in the diagram?
Cheers, Phil
