Constant graphics driver crashes?
PitfireX
Renton, WA
3 months ago I had this issue and I posted this post here
Quick summary; both screens going black 10 seconds or so after launching a game or benchmark software. I replaced my old GPU with a new one and didnt have the issue anymore. (although it should be noted that the old GPU works fine in a different computer)
Today I began having the same issue again. after about an hour of gaming, screens go black again. Could this be a non hardware issue and a software conflict?
ATMINSIDE
What have you tried this time?
Clean install of drivers?
What temps are you hitting?
What driver version(s) have been tried?
P
PitfireX
Renton, WA
I haven't clean installed drivers. I've updated like 8 times since putting the 970 in and just updated again today after the first black screen.
I havent been watching temp, but I dont think I should be overheating ill watch it now.
ATMINSIDE
After recording the temps in game do a clean install of the nearest driver version.
Dlaw
New York, USA
I haven't clean installed drivers. I've updated like 8 times since putting the 970 in...
This is likely the problem. +1 to ATM, definitely do a clean install. Make sure you MANUALLY uninstall everything related to NVidia in Add/Remove programs in control panel, starting with Geforce Experience (if installed), PhysX-3D vision controller-3D Vision driver-HD Audio and then finally the Graphics driver.
Then, get DDU, and run that in safe mode. Then install the new driver, making sure to click Clean install during installation.
P
PitfireX
Renton, WA
When I woke up I couldnt get the screen to come on. im inferring that it crashed again, outside of a game this time. Why don't drivers have crash logs?
Dlaw
New York, USA
Also, are you sure that it's the graphics card not bringing the monitor up, and not the monitor just refusing to wake up? I have that happen with mine quite often, the only way to bring it back is to unplug and plug it back into the wall.
wingman99
+1 when your screen wont come on try unplugging the connector and reconnecting to see if it is your monitor.
P
PitfireX
Renton, WA
Im assuming if it was my monitor, i would hear the device disconnected sound and not the "Windows Exclamation" sound that I am hearing. Also its happening to both monitors at the same time... Just happened today with nothing but chrome running.
wingman99
I agree it is not your monitors. Have you tried to do a clean install with downloading Nvidia driver then do a manual install and check mark clean install?
P
PitfireX
Renton, WA
I just formatted hard drives and completely reinstalled windows... same problem.
So I read somewhere that a guy fixed this issue by taking his second monitor from Display Port to HDMI. I unplugged my second monitor which is an ASUS VE278Q (hooked up via display port)
and I havent had the issue for an hour or so. Presuming I found the problem, what could cause this?
P
PitfireX
Renton, WA
Okay here's what im noticing. Luckily the issue normally happens after only a few minutes of in game so I can run tests quick.
so far with a display port monitor connect to ANY of my 3 display ports = Issue
With the second monitor connected via HDMI = Issue
With HDMI connected to GPU but NOT connected to a monitor on the other end (connected to nothing on one end) = Issue
ONLY Primary monitor connected via Dual Link DVI = NO ISSUE
