- Jan 23, 2003
- Ft Worth, TX
Has anyone been having issues with Windows 7 requiring a constant repair of the startup?
After installing the Student version on a clean disk (was XP pro), i have had constant needs for repairing the startup.
After install it worked fine for 4 or 5 boots, then it stopped seeing the USB keyboard on boot, once repaired and booted the keyboard was fine. I thought i had fixed by just going back to a regular old PS2 keyboard.
Then i started noticing the same issues with a thumb drive. If it was plugged in when the computer was booted down and then removed while booted down, i would get startup errors on reboot that required repair. I figured that was OK as long as i remember to remove my drive before i shut down.
Last night however i had another one. It was the 1st boot after doing a complete system backup. I started the computer and was again prompted that the startup was halted and to insert the Win 7 disk.
All in all i like Win 7 but since installing it on oct 23rd i've had to use the disk to either repair or boot from 15-20 times...It's getting a little old.
