funtikar
- Sep 24, 2015
To understand my situation I'll explain a bit
So from my previous setup
Dell optiplex 755 customized build
MOBO : BTX proprietary mobo
PSU : 280w
CPU : Core 2 Quad Q6600
GPU : Asus GTX 750 2GB GDDR5 non ti
RAM : 6GB DDR2 only
This was working fine but I wanted to upgrade the mobo to MSI(ex NEC) MS-7594 (Intel G45/43 chipset), this basically means upgrading the casing as well
so I tried to build this
MOBO : preused MSI ( ex NEC, it was from a commercial NEC MATE PC model MY30AAZ77 ) MS-7594 rev 1.1 (G43 express )
Casing : Powerlogic Futura XV110
PSU : 450w
CPU : (same)Core 2 Quad Q6600
GPU : (same)Asus GTX 750 2gbgddr5 non ti
RAM : 4GB DDR3 dual channel
BIOS : AMI 2.59, bios version 469A0600 ,
the problem is after I switched on power... it just continuously beeps with no display.
So I tried eraser technique for RAM because many said thats the problem but its still the same,
I tried removing the GPU and so straight VGA from integrated graphics still same,
I never thought its the Processor but after changing the Processor to Core 2 Duo E4500(luckily i have this stock dell processor) it just boots and everything works , including the RAM and the GTX 750 also works...
is it incompatible? but I thought G45/43 supported C2Q and why does it continuously beep ,shouldn't that mean its the RAM fault?
I actually tried to boot my old system with the Core 2 Quad Q6600 Processor, its working, so its not faulty
I found a japanese site which provided a bios update , so I upgraded my BIOS from 469A0600 to 469A0601, I thought that it would enable me to use the Q6600 but to no avail
I've also found a guy on youtube who managed to upgrade from C2D E6550 to C2Q Q8200(a core 2 quad but still not a q6600) for his NEC PC MJ18XA(MS 7594 mobo too), Im currently waiting for his reply on anything he did to upgrade his CPU,
is there some bios settings/update thats preventing me to use the Q6600? is this it?
PSU : 280w
RAM : 6GB DDR2 only
PSU : 450w
