Controll cpu fan from windows?
Quattro
Hey,
Is there a program to control the cpu fan from windows, it is on my second rig. I'm just trying to make it quite for a all night download session.
I'm going to under clock it and reduce the fan speed, it is not a stock one it is a copper coolmermaster one that plugs into the motherboard.
Any suggestions?
EDIT: It might also plug into a molex... not sure.
If it matters I'll find out.
Bios24
Kansas City, MO
Motherboard Monitor 5 (MBM5) and Speedfan are both good. You might look through the software that came with your motherboard also, a lot of newer boards have monitoring software included. (mine can with SilentTek)
Quattro
Quattro
Second rig is using an Abit KT7A-RAID...
Not sure if this has it.
I've got MBM5 already installed on it, I didn't realise I could controll the fan speed from there!
How?
a c i d.f l y
Austin, TX, USA
I don't think you can do what you are trying to do.
The only way to slow a fan down is by reducing the voltage flow to the fan.. until there's a hardware mod with software drivers, nothing in Windows will control fan speed.
I suggest any kind of rheostat -- pick it up at your local Radio Shack.
-Frank
magick_man
Forum Magician
Bedford, Texas
plug the cpu fan header into a case fan header and use speed fan to throttle it down.
make sure to turn off any kind of cpu fan protection :)
~Magick_Man~
Bios24
Kansas City, MO
-Frank
Actually the software that came with my AOpen board can do just that. It's called SilentTek. I can turn the fans to zero if I wanted it, it can also automatically adjust fan speed with cpu/case temps. Too bad the board only supports 2 fans this way.
