Hello everyone,
I'm running an H80i and I've recently decided that I've had enough with the noise it generates (Stock fans range is 600RPM-2800RPM, which is great if you can set a good fan curve but bad otherwise). Thus I've set myself a goal: Be able to enjoy a nice, quiet system, which ramps up its fans when under heavy gaming load. I am using it to cool a 4930k @ 1.35V, and my motherboard is Asus P9x79 LE. Here are the solutions I've tried thus far, but non of them works perfectly:
1. Tried Corsair Link. Software does exactly what I want it to do... sometimes. However, it has some collision with the GPU (either with the drivers or with MSI afterburner), resulting in signal loss. It also freezes rather randomly... Good tool when it works, problem is it never works.
2. Tried connecting the fans to my motherboard Chasis fan connectors. The problem: BIOS fan control is questionable. First, I cannot set the fans to go below 60% (which is >1500RPM). Second, I cannot set them to change automatically according to CPU temp, only Chasis temp, so it is meaningless. SpeedFan doesn't recognize the fans.
3. Tried connecting the fans to my motherboard CPU fan connector. I've done this with a PWM splitter (hopefully it won't cause the header to degrade). Bios control is still meh, so I went with software control. Now the problem is divided into 2 different problems:
a. SpeedFan recognizes the fans, allows manual control and has all sort of options (Manual, Thermal Cruise, etc..). It has the option to set a fan curve... But no matter which option I pick, I cannot get the fan curve to work. Manual control works as intended, so this is probably a software thing
b. AI Suite II, which is the other software I use, has the option to set a fan curve. It works. However, the reference temperature is the motherboard CPU temperature, which for some reason, doesn't display the real CPU temperature. For example, if I run Prime95 and RealTemp, the individual cores run at the 60c range. However, the AI Suite sensor will say the temperature is in the 40c range. Problem is that we're not talking about just an offset, it's inconsistent with the lower CPU temps and it will change randomly when under load.
So, here are my questions:
A. is there a better way of controlling the fans which I've not discussed here?
B. How can I configure SpeedFan to actually run the defined fan curve?
C. Is there a way of calibrating the motherboard CPU sensor?
Thanks!
Thanks!
