Hi,
Im using a Intel XEON X5680 (3.33 GHz) and OC'd it right now up to 4+ GHz stable (HT off, BCLK 150 x26 or BLCK 205 x20). The CPU can take it fine under Prime95, but its getting way to hot. I think when I can pull more heat out I can get another 400 MHz maybe.
The idle temp of the CPU is 45 °C. In Prime it goes over 95°C if the OC goes hits 4 GHz.
But I still have fresh high quality cooling paste and a Noctua NH U12P massive Cooling Tower with 2x 12mm fans on it. What can I do?
(maybe sucking in 2°C air via duct from the Window? )
