- May 24, 2001
- Maine, USA
I never had a problem with the 11.00 drivers for my Geforce2GTS and GTU/coolbits, until I replaced my MB with an AsusA7M266. When I reboot after making a change to the Geforce Tweak Utility, my monitor is all distorted with funky colors and patterns. I have to go into safe mode and install the 10.80 drivers, then I can make a change to the GTU, reboot and all is functioning well. Also, I know the 12.41 drivers do not support coolbits, but when I try to use the .exe installation program, reboot, I get the same distorted screen as with the 11.00 drivers, but without having made any changes to the GTU. Since the 12.41 drivers are a self installing file, is there still a need to first remove the previous drivers, then run the .exe program?? Or will the 12.41 drivers simply overwrite the (ex. 10.80) drivers?? Is anyone else having difficulty using GTU/Coolbits with the 11.00 drivers??
Thank you....
Thank you....
