Coolbits
tragic_monkey
London, UK
Does anybody know how i can extend the Core slider bar beyond 315MHz i know i can be done by some other coolbits registry hack using the simpsons names i just donnt know how.
Also has anybody had a better overclock/performance by updating the bios on the same card (see sig)
1. Open up the Registry Editor(Start/Run/Regedit) and hit F3(Find/Find Next).
2. Type Bart
3. Continue hitting F3 until you see the "Simpson's Page", names like Bart, Homer, Krusty, Marge, and Lisa should appear.
4. Right-click on Bart, choose modify, change the number to reflect the same one that is in Krusty
5. Exit and Restart
cheers ronin1967
and ThePunkGeek i can use powerstrip to get higher only i dont like it and you have to pay as its only a trial
2. Type Bart
5. Exit and Restart
i have no Krusty key, just homer, lisa, bart, & marge. . . :( ????
try creating a dword named Krusty with a value of 77c4aac0 thats what mine had, also have you enabled coolbits to begin with
nevermind had to apply the new clock at start up before the krusty key is made... found that in another thread :) search = good
