Cooler Master HAC-V81 - is it ok??
2500+RPM
USA
Is this is good heatsink and fan.. its got speed controll up to 4500RPM but my monitor says it goes up to 11000RPM
anyway is this a good heatsink and fan?
im using it on a 2500+
Thanks, Ryan :cool:
It's a heatsink with an outstanding price performance ratio!!! ;)
I just bought one for me as long as I have to wait for the parts for my Swiftechs and my new Zalman CNPS7000A-Cu.
I got it today, gave it a good lapping (really needed) and will try it out on my new CPUs (XP 1800+ JIUHB DLT3C 0321 XPMW and XP 2000+ AIUHB DUT3C 0322 RPDW) soon this afternoon.
It should be a really good performer at the high RPM ratings of the fan, so let's say from 3000-4800 RPM. Any lower and the performance will only be midrange.
But all in all, it's unbeatable for 10,90 EUR including shipping(around ~12$).
So if you're looking for a cheap good performing heatsink/fan combo with adjustable fan, all I can say is:
GO FOR IT!:D
The fan is a bit noisy, if you can get Xdream SE it's better, pure copper. Also i had problems with the mounting clip, because my case is a bit small and when i put the PSU i can't screw it. So i repleaced the clip with the one which came with the box cooler with the cpu
I've had that HSF for about 6 months now. It's been working just fine for me and the price was right. I have the fan at the lowest speed to keep the noise down and backed my overclock off a bit ([email protected] V) to keep the temps in line.
I'm planning on picking up an NF7-S and Barton 2500+ next week (passing my current CPU/MB to my kids). I'll likely spring for a Thermalright SK-7 (around $20), but I'm curious to see how the retail HSF does first.
