Hello all.
Anyone with this case know if you can mount a h100i aka AIO cpu cooler in the top radiator bay with the fans inside the case? Seems like there is some plate between the radiator bay on top so you wouldn't be able to run the tubes through, hope I am wrong as it all depends on this wether i buy it or not. Else i would have to cut a hole in the plate thing to run the AIO tubes through.
I know I could have the rad inisde the case and the fans on top inside the bay, but that is not how i want it.
