Cooling a 2600+
xCarne_Asada
The OC, CA
what would be the best AIR cooling solution for an AMD 2600+ Processor? I am thinking a ThermalRight SLK-800 and a Sunon 50CFM Fan with some AS3. Does this seem like it would work effectively? I am trying to keep the noise down.
Lord Moreira
Banned till 9/16/03
U.S
YES
NO get this 1
YESHERE
As for the wire guard from Tt that comes with it u would need to screw it to the fan itself
No biggy ;)
xCarne_Asada
xCarne_Asada
The OC, CA
well i am just going to order it with like 3 fans, and see which one is the quietest with the best cooling, then use the others in other computers, damn i wish watercooling was an option
Codeman05
US
Well I'd say a SLK 7 or 800, and a sunon 84CFM fan. Main reason I say that is I got the SLK7 and the fan for under 30 bucks, and with the 7volt mod or a rheostat its really quiet (or maybe I've just gone deaf)...and if you do go the way of a rheostat you have ALOT of "play" with different CFM/noise/temps
