Would you recomend if i use an standard cooler designed to work with an Duron 900 for my 750 MHz? Would that make a big diference?
My current normal temperature in windows is 43ºC.
I've got a Duron 750 and have gone off the deep edge and am using watercooling. However, it's expensive and messy to start learning. If you want good stock cooling go with the glaciator. It's an all-copper heatsink. SOme good places to shop are :http://www.plycon.com and http://www.2cooltek.com
