I'm still in the designing stage of my water cooling and I have a question about the temperature of the water.
Some bluepaper specs so far for the reservoir:
About 20x14x40cm (WxHxD), made from sheet-metal or some such.
It'll hold about 10~11 liters of water. 2xTemp sensors (LCD) & waterlevel-window made out of plexiglass. Attached with rails under my case (Antec SX1030).
Would that amount of water keep the water temp low enough for me to just recycle it thru the pump to the waterblock? My CPU pumps about 70W of heat currently... If not, could I attach a low-power peltier (30W?) to the back of the reservoir (outside) and cool the with a heatsink? The heatsink would be 97x130mm. Sideprofile of the HS attached as an image.
Oh, I could use my PEP66 without a fan also.
