I recently OC'd my laptop, a 700mhz celeron (not a great cpu at the best of times), and after taking it to pieces emerged with a laptop cpu now clocked at 1.4ghz, double the original clock speed. This setup is great and incredibly stable (it has yet to crash after 3months at that speed - having run both the prime95 torture test and having been on perpetualy without restart for 2weeks whilst I left it Folding (for team 32 of course). A good OC you'd say, although laptop oc'ing doesnt seem all that common as far as I can see.
However, being a laptop means just that, a pc you can put on your lap. This one after 6 or so hours of use becomes so hot that it starts to burn you through your trousers, and for prolonged use I put it on a heat proof mat on the table. so what i wanted to know is -
How do I mod or cool an OC'd laptop for reduced temps??????
it has one 20mm and one 40mm stock fans in it at the moment, and heatpipes on the cpu that run to the 40mm. Any ideas??? if nothing works I may have to downclock it back again...sigh...
Thanks
Vrykyl
Thanks
Vrykyl
