This is a VERY rough draft of what I'm looking into doing (pic below). 120mm fan in front of machine funneled into 2.5" flex tube (not metal) which will drop right on top of the HS. The HS will have no fan, and have to be custom made to mount thru the motherboard holes due to the possible weight of the tubing (which will be secured though). In addition this will allow the HS to be approx 3"-3.5" tall. The drawing of the tubing is poor, it will acutally curve out on the far side of the case missing the cards (2.5" is my clearance there) and come straight into the HS. The tubing will slide down the entire heighth of the HS with proper holes in it for the air to escape at the bottom.
Here are my thoughts on the benefits of this:
1. Incredible air flow.
2. Cool air drawn from outside the case.
3. The heatsink will be larger since theres no fan on it.
4. The closed system will keep warm air from recirculating back into the HS.
I visualize this working at least as well as a watercooled system. Of course, I'm not an engineer or anything. Flame on baby!
Survey says?
Survey says?
