- Jun 8, 2005
I recently bought an alienware area-51 which i gutted and upgraded. I took the components i removed and decided to build a media center pc. I chose an Antec Aria case for its size and reviews. I install everything and did the best to clean up wiring mess. My problem is that the cpu runs idle about about 52 degrees and over 60 at load!!
my cpu fan is so loud i can't hear the tv! I watched it hit 4400 rpm the other day. I've read a bunch about ppl using aftermarket cpu coolers as i am using stock, but most are running socket 478... I don't have that much room. My stock intel heatsink barely fits.
here are my specs:
ASUS P5GD1-VM MOBO
Intel Pentium 4 520J LGA775 processor
2x256 dual channel ram
diamond stealth s60 vid card
antec aria matx case
stock antec psu
any low cost ideas needed. I want my temps in the low 40's. If I can't I will sell this setup, though i would hate to as it boots up alienware logo, and has all the alienware themes and such. Hopefully someone has experience with this case and processor??!!!
ASUS P5GD1-VM MOBO
stock antec psu
