- Feb 7, 2002
- Alberta, Canada
Need some peoples opinions since I'm pretty sure they'res alot of people in here that know more than me about ov'ing
So any feedback to this problem would be appreciated...
System:
Running Windows XP Professional Build 2600
AMD Athon 1133mhz@1266mhz (133x9.5)(4:4:1)
Abit KG7 w/256 Crucial (Micron DDR ram)
Diamondmax 15.3GB HD
Geforce2 GTS 32mb
SB Live! Value
Aopen Power Supply 300watts
I have a Aopen 24inch case with a 120mm Global Win 105cfm fan as a front intake and 2 80mm sunons above my PS as outtakes on the back of the case for heat... On my processor I have a Global Win FOP32 w/38 cfm fan on it... System temp average between 26-27c... and processor idle about 35c and full load ~41c.... this is all at default voltage (1.75)... and 1266mhz.
Now I guess its more electrical than heat... But I can get my comp to post up to 1600mhz!... unfortunetly I can't get windows to post worth ****... the one thing I can do is get it post at 200mhz at 1300mhz bus... and I've tried cranking the voltage up to 1.8v and that didn't do anything to change the situation... My MBM 5 readout says at idle I'm sitting at 5.03... where when im at 1133 I'm sitting at 5.05... so maybe PS is too small?...
I guess I'd like your guys input on a simple question, in this current situation do you think the reason I can't get into windows is because of my power supply, heat, or some other factor I haven't considered....?
Thanks for any help guys!
- WyDster
System:
Geforce2 GTS 32mb
SB Live! Value
- WyDster
