Cooling that cought my eye!
T1Cybernetic
West Yorkshire, UK, Earth!
Not sure if this is fully ok to post as it's a for sale add on another forum but
when i saw it it really caught my eye and got me doing some research into it.
check this out >> http://www.cpucity.co.uk/forums/index.php?act=ST&f=15&t=1957
Anyone here using something same /similar as that is something i would really love
to try and it appears to be a cheap but effective way of cooling things, :D .
Appologies if this isnt allowed but i didnt know exactly how to put this accross
without a bit of info for you to compare with but as you can clearly see the pic
and description i thought it would help me get the message accross.
Im looking for alternate ways of cooling similar to this and im actualy considering
contacting that person to ask a little more about it as the price appears to be ok.
Looks to be a chilled water system from what I can tell. That type of post is allowed here, shows different ideas, and you are not advertising it here.. It's more applicable to the water cooling or extreme cooling section though.
I'd bet it works pretty well.
If you want to go extreme, maybe it would be better to go with simple phase change - check Extreme cooling subforum.
Thanks for the replies, im looking for something other than air cooling thats all but watercooling
is easily done nowerdays and cheap enough if you know what you need and know where to
look so i figured i would go for something a little exotic so to speak and that one make me want!
so i just thought i would bring it to someone elses attention to see if anyone was using
something similar or even recomend something a little similar as the one posted.
By the way, Im checking the other cooling sections out now, :D thank you.
