I have my CPU being cooled by my liquid cooling loop. The rest of my system is currently not attached to my cooling loop. (This is hypothetical right now but I do have the means to make it a reality, Just want to check on a few things first)
If I cool the ambient temp inside of my computer case down to very low temperatures, will the reverse happen with condensation like when you use a TEC cooler on your cpu or a phase change on your cpu without proper insulation.
So, Cool the ambient temps within the Computer case to (lets just pick a number below ambient air temp of the room) 5 degrees Celsius. Since the average temps of my GPU's is around 45 degrees Celsius when idle, will the 40 degree temp difference between the hot graphics card and the cool case cause condensation?
I know if does when you have a very cold component in a hot case, but what about a very hot component in a very cold case?
(GPU's taken into consideration but will this also be the same with the motherboard, ram and other non water cooled components?)
Thanks guys!
Thanks guys!
