- Dec 17, 2000
as some of you may know I got a 5 foot 4 inch water tower.....
25 liter reservoir, and my CPU runs under ambient temps...
celeron 633 @ upto 2.1 volts 1066
right now 1017 1.9 volts
had to replace some capacitors on my motherboard as I blew them (1066 was just to much)..
but the newer ones should take the voltage better.
rated for 25 volts old ones for 6.3
room temp is 28.1C right now
cpu temp 20C (33 watts) (winamp , IE is the only load its under right now)
lapping my danger den waterblock (maze 1) helped alot (1500 grit)
Water does evaporate very fast with this setup.
as I got a 80MM fan @ 12 volts....
I think it is blowing water out of the tower as I can feel a slight mist if I put my face over the top of the tower.
I am losing about 2 liters a day like this.
When I have the fan turned of maybe 1 liter a week, if that.
I think I am going to do some test at 3.3V 5V 7V 8.7V
if you know how to get any other volts from a ATX power supply plz tell me ( between 3.3 and 12.
I am running this fan off a second PSU so I got more options than the 4 prong connector that most fans run from.
gona put this system under full load for a few min
tell you the temps I get from that
I use CPU Stability Test 6 Build 154
this is the best to test your system with, if it passes this its stable, if it fails
well I lost 3 capacitors
e-mail me if you want it
