cooling
sludge
israel
hey ppl,
i am runnin an amd2200+ @ 2000mhz,
it is 28.5C idle, 30C loaded thats preaty cool i know but the system temperature is 9c - idle. 12c - loaded,
is it 2 low?
or is there no such thing as 2 cold ?
sludge said:
hey ppl,
is it 2 low?
There really is no such thing as too cold with air cooling. Now, if you use some extreme cooling such as a Peltier or Prometia, you have to take precautions to prevent condensation of water which can run off....and you know the rest.
Hammer
Ummmm - unless you are using active cooling (i.e. peltier) or live in the arctic then yes, those temps are too low.
With air, you should never be reading below ambient/room temp.
And 30C CPU temp in an normal 22C room is just plain too low - its not real.
i am using a volcano 7+ about 6 50m case fans , and i got a tube from the airconditioner into the case with a 120mm fan.
however my question was, if running at VERY cool temperatures is a bad thing? or is it a good thing?
