I have both of these coolers lying around, I am currently using the Coolit dominoe at 1.35vcore and 1.35vQPI/Dram. Would the Scythe Mugen 2 do better or the Dominoe. I have an extra fan I need to figure out how to use, but I can make either of them push pull if its better.
I would just pull the ALC out but the scythe is so freaking hard to install, if anyone has an i7 with around the same settings let me know. Or if you just have some input let me know. My i7 runs ok right now at around 34 degrees idle 75-79 full load at 3.8 ghz. I am always trying to get 4 ghz out of it though so every little bit helps, my pc crashes sometimes when running Prime95 after 30 or so minutes, but the temps are still fine?
