- Dec 6, 2017
Hello!
I'm honoured to join overclockers community. The main reason I joined is because I hope to find a solution for the issue that I have with my laptop and I thought this would be the best place to ask:
I replaced the thermal paste in my laptop (dell precision M6800) with Coollaboratory Metal Pad and it was all spring and cool for 1-2 weeks. Problems started to appear slowly, after that period when the overall temperature on my cpu started to increase and now is acting really strange when on maximum performance (when cpu stays always to 100%):
- when doing simple tasks like opening Internet Explorer or surfing the web, it has sudden thermal spikes to over 90 deg. Celsius, for a very short period.
- when the spike occurs, the fans go to full speed for few seconds and then they calm down.
- when on high stress, the cpu goes over 95 degrees
Mentions:
I would welcome any input from whoever used Coollaboratory Metal Pad and could help me to rule out the problem.
My thought right now is that it may have happened to build some thin layer of something (oxidation, for example) that prevents a proper heat transfer from the cpu to the heatsink, despite the presence of the metal pad. Could that be a thing?
Many thanks!
Mentions:
- Yes, I burned-in the foil after I applied, by putting the laptop on the bed and firing OCCT until my cpu and gpu got aroun 70-80 degrees Celsius.
- Also, as I mentioned above, all was perfect the first 1-2 weeks.
- This is the second time when I apply the Metal Pad on my machine. First time it happened the same (was all perfect for more than 2 weeks, almost one month, when it went hot again)
- A while ago I used XTU to play with my CPU (and I managed to get it into a sweet stable spot, by the way... but after a lot of trial) - could that damage my cpu? But if so, it would manifest immediately, not after weeks, no (also see pct. 4.) ?
- Before applying, I cleaned the CPU with isopropyl alcohol and let it to dry
- Also, before applying I sanded the copper plate on the heatsink with 5 micron lapping film until I cleaned all the oxidation and then I rubbed it with isopropyl alcohol
- I applied Coollaboratory Metal Pad in my wife's laptop and there is no problem for months already (that one is way less performant, but still, the cpu stays cooler than it was originally)
Many thanks!
