- Jun 20, 2001
- Vancouver, WA
Hey! I have an idea! I don't know if it would work, if it would make temps better/worse, or anything at all, but it is an idea...
What would happen if you electoplated (or plated in any way) a copper heat sink with aluminum?? I read somewhere that copper has a higher heat transfer rate than aluminum, and aluminum conducts heat into the air better than copper... So what if we took the best of both worlds and coated a low resistance copper heat sink with a high air transfer rate aluminum coating?
Just wondering if this would work. Might there be any chemical reactions between the copper and aluminum that would be bad for the HS, or would the small amount of aluminum not make much of a difference? If so, are there any HS manufactures that make copper heatsinks with aluminum fins? I've been thinking of such a heatsink for a while now, and was wondering...
JigPu
JigPu
