- Jun 30, 2001
>How heat transfer to air via convection is not material dependant (except for the
>properties of the air itself...
OK, lets suppose that we have a given volume of flow for both water and air. Is it not the thermal properties of water versus air which determines that water will cool better than air? ( rather than something like viscosity.) Why then is it irrelevant to the heat transfer what the thermal properties of the sink are? Sure the heat is carried away by convection, but the transfer of heat from the sink to the fluid is by conduction. A unit volume of water takes up more heat than air, and that seems to be the relavent property. If aluminum gives up more heat per volume unit then copper, that would seem to be the relavent property.
I did find a design sheet for heat sinks that had some formulas. Unfortunately, the design procedure works in a logical circle and involves using a "nomograph" look up, so I couldn't guess much about what the thermal resistance does to the effectiveness of a heat sink. Except for emissivity, no other property of the material enters into the figuring. Emissivity enters into heat radiation part, but not the heat conduction part. Whether the properties of copper are slipped in via the "fin effectiveness factor" I couldn't guess. But the temperature difference enters into the thermal resistance calculation as the fourth root. No wonder copper sinks perform so closely to aluminum sinks, even though copper is twice the conductor aluminum is. Still, the forth root of 2 is 1.19 so one might expect copper sinks to be 20% better than identical aluminum sinks, which does not seem to be the case.
BTW, the myth is alive and well. At
They review a silver plated copper sink, and say the silver plating "gives it a higher heat dispersal rate than Copper ."
They also have this copper-aluminum babe. I don't think they were trying to save money or weight on this one:
The Swiftech MC-462A Rev1... the heatsink itself is comprised over a copper bottom and aluminum pins. Weighing in at 760 grams its attachment method alleviates any concerns you might have because of the weight.
