Tried copper antisieze before. The oils it's mixed with are detrimental. Stick with normal TIM.
And I'd be worried about the electrical conductivity issues from even the slightest mistake.
Oil is an insulator. It does not pass heat as well as the silicone based TIM's.
Not as bad as you would think. It falls in the middle of the pack of normal TIM's. What I particularly didn't like was the fact that it got runny when hot, and the conductivity factor scared me off. Mind you I did this on bare die processors. An IHS might be different. Conductivity will not change though. You will need to be neat and careful.
There are about a billion threads out there about people trying this. Results are all over the scale.
It more of a "let's see what works" deal then how much can I save deal.As far as a copper grease goes... Might do ok. But how much money are you really saving? I've had a tube of AS5 in my desk for several years. I use it a tiny dab at a time. Less than $1 per application? And silver conducts far better than copper. Diamond better than silver... etc, etc..
How are they detrimental?
Not any different then the tim I use now. In fact I use electrical conductivity tim for the most part.
If there is metal in the paste, it will conduct electricity. Period.Dear all.
I see many people are worry about copper grease will short circuit computer. In fact, it is safe.
Because those copper powder mixd in copper grease just for fill some copper contact surface to decrease contact resistor.
Copper grease is help for increase conductivity but it wont conduct itself.
Please correct me if I wrong.
Thanks.
Thanks for Wagex comment.
As I know copper grease design for very high temperature almost 1100 C, but Arctic silver is for 200 C.
I think copper grease will survive longer in high temperature.
And copper grease is cheaper.
Thanks.
