Copper heat spreader
RoadWarrior
Senior Member
Niagara Falls, Ontario, Canada
Hi guys,
I've just found some copper sheet, it's kinda thinnish though, around 0.7mm, just wondering if that is thick enough to be worth the bother of cutting a spreader plate out of to go on one of my K6-2s, that I denuded of it's ally pressed plate. Do you think it will have much effect? Or d'ya think the extra thermal interface will kill any small advantage?
thanks,
Road Warrior
i dont think it would be worth it, because it would be very, very difficult to get that thing on correctly, and would hurt more than it helps
