- Jan 11, 2001
I guys I have a Celeron 600 cC0 running at 900 Mhz and use Motherboard Monitor and a Radio Shack temp thing to measure teh temp, and I wanted to try adding a copper shim so I got some arctic Silver II and spread it over the whole Gorb bottom and then placed the copper shim around the CPU core, I looked and looked and looked but I couldnt tell if the CPU was making solid contact with the Gorb, so I took it off and the CPU has a thim layer of Silver on it so I decided to leave it and try it like that.
Im getting readings of around 28-33 now from idel to full on usage so should I assume everythign is ok, or is there a better way maek sure that there is a good amount of heat disapation going on?
thanks
thanks
